Disables RADIUS accounting.
| mgmt-access | Specifies the switch management RADIUS accounting server. |
| netlogin | Specifies the network login RADIUS accounting server. |
RADIUS accounting is disabled for both switch management and network login by default.
Use the mgmt-access keyword to disable RADIUS accounting for switch management functions.
Use the netlogin keyword to disable RADIUS accounting for network login.
If you do not specify a keyword, RADIUS accounting is disabled on the switch for both management and network login.
The following command disables RADIUS accounting on the switch for both management and network login:
disable radius-accounting
The following command disables RADIUS accounting on the switch for network login:
disable radius-accounting netlogin
The mgmt-access and netlogin keywords were added in ExtremeXOS 11.2.
